dsnpevl
Jan 02, 2015Virtuoso
After backup: Destination is read-only?
I'm working on implementing a proper backup procedure as most experts on this forum recommend. But when trying to backup a large amount of data, I keep getting this error message: Backup: Error bac...
- Aug 01, 2015
Have been looking for a solution for this problem for a long time, but never managed to find the root cause.
In the end, I decided to remove the offending subdirectory that contained a file backup of a Windows system. This solved the problem with the backup procedure.
dsnpevl
Jan 05, 2015Virtuoso
mdgm wrote: Can you send me your logs (see the Sending Logs) link in my sig?
Logs are in the mail.
mdgm wrote: Do you still have this issue if you connect the USB disk to the front USB port on the NAS?
Hadn't tried that sofar. I intend to backup > 4TB to a USB 3 disk, so connecting it to the rear USB 3 port seemed the most logical thing to do. I am now trying a backup on the front USB 2 connector with the share that is causing the problems . But it may take quite some time to back it up on USB 2, as the share is quite big.
I made sure that dirs and files on the disk have no read-only nor archive flag set:
F:\>Attrib -R -A /S /D
And chkdsk found no errors:
F:\>chkdsk F:
Het type bestandssysteem is NTFS.
Het volume is in gebruik door een ander proces. Chkdsk
rapporteert mogelijk fouten ook als er geen beschadiging is.
Volumenaam is Disk1.
Waarschuwing. Parameter F niet opgegeven
CHKDSK wordt uitgevoerd in alleen-lezenmodus.
Bestanden controleren (stap 1 van 3)...
1332646 bestandsrecords verwerkt.
De bestandscontrole is voltooid.
0 records met grote bestanden verwerkt.
0 records met beschadigde bestanden verwerkt.
0 EA-records verwerkt.
0 reparserecords verwerkt.
Indices controleren (stap 2 van 3)...
1332806 indexvermeldingen verwerkt.
De indexcontrole voltooid.
0 niet-geïndexeerde bestanden gecontroleerd.
0 niet-geïndexeerde bestanden hersteld.
CHKDSK controleert de security descriptors (stap 3 van 3)...
1332646 bestands-SD's/-SID's verwerkt.
De controle van security descriptors is voltooid.
80 gegevensbestanden verwerkt.
Het bestandssysteem is gecontroleerd. Er zijn geen problemen vastgesteld.
5723132 MB totale schijfruimte.
310968 kB in 75 bestanden.
20 kB in 82 indexen.
0 kB in beschadigde sectoren.
5578976 kB in gebruik door het systeem.
Het logboekbestand neemt 65536 kB in beslag.
5717381 MB beschikbaar op schijf.
4096 bytes per cluster
1465122047 clusters in totaal op schijf
1463649556 clusters beschikbaar op schijf
By the way, the read-only checkbox in the Windows UI is a bit confusing, as explained here.
