dsnpevl
Jan 02, 2015Virtuoso
After backup: Destination is read-only?
I'm working on implementing a proper backup procedure as most experts on this forum recommend. But when trying to backup a large amount of data, I keep getting this error message: Backup: Error bac...
- Aug 01, 2015
Have been looking for a solution for this problem for a long time, but never managed to find the root cause.
In the end, I decided to remove the offending subdirectory that contained a file backup of a Windows system. This solved the problem with the backup procedure.
dsnpevl
Aug 01, 2015Virtuoso
Absolute1
Aug 02, 2015Aspirant
Sadly, I wish that was the case for our customers! We've now tried reformatting the backup drives as NTFS and HFS+ but the problem always comes back at some point.
Netgear still have problems using USB external drives and backup, which after nearly 2 years, needs fixing.
- dsnpevlAug 02, 2015Virtuoso
The configuration is cumbersome, but I managed to configure backup of volume:data to USB right USB to dir /data.
Plans are for me to build a backup scenario with 2 external drives around that.
