495brian
Nov 14, 2016Aspirant
After Factory reset, quickest way to X-Raid2 with Dual redundancy 6x 2TB drives (RNDP6000)
I have 3 of the pro ready NAS drives (6 bays), one business and to readynas pro RNDP6000. One is set up as the "in use" drive and the other two are for back up. The "in use" drive was set up as XRAID2 with redundancy. Back then I didn't know how to do the dual x-raid 2 redundancy and thought this was two layers deep before data loss. I was wrong. When a drive is compromised, I replace it immediately, but the volume is not protected. I've had bad experiences with single redundancy. When one drive fails, they start to tumble like a house of cards. The back up drive is set up as x-raid 2, dual redundacy and functions very well.
I have the third drive that I would like to set up as the new "in use" drive and tried to quickly set it up as dual redundancy with x-raid2.
I dropped 6 2TB drives in and booted it up. The menu didn't let me choose dual redundancy and it appears that the only option was xraid2. Is there a sequence that I need to do this? Start with one drive, expand, add, expand etc (repeat for 5 drives?!). I downloaded the most recent OS x.x.30 (I can't remember the numbers but can update this when I get to work).
Can someone tell me the quickest way to set this 6 drive array as x-raid 2 with dual redundancy. Without any data on it I don't understand why it takes so long to "set up", what exactly is being copied for configuring drive 6?
I read on an old post that the older versions of the OS allowed users to select dual redundancy, so perhaps this is the answer. Thanks if anyone still checks this and knows the solution.
What I suggest is installing 5 drives first, and let it set up as XRAID-2 single redundancy. Then set the system to "add the next disk for redundancy" and hot-insert the final drive. That might not be "quickest", but it works reliably the first time.
RAID basically creates a virtual disk volume that sits between the physical drives and the file system. Each sector of the volume is protected by the RAID partity blocks - the RAID layer has no idea if the sectors are used or not. During the sync process, the system is mostly computing the parity blocks.
- 495brianAspirant
Thanks so much for the advice!
- mdgm-ntgrNETGEAR Employee Retired
The quickest way on RAIDiator-x86 would be to do a factory reset, click setup in RAIDar during the 10 minute countdown and choose X-RAID2 and check the dual-redundancy option.
On OS6 the quickest way would be to disable X-RAID, delete the default volume and create a new one using RAID-6 and then re-enable X-RAID. It's preferable to call the new volume "data" (no quotes).
- 495brianAspirant
Hi All- Just an update to the process for other out there. The reboot with 5 drives was quick, less than 10 minutes to set up and establish a new volumne. The 5th drive to re-sync took about 4 hours, but I let it run overnight. Following this completion a login through RAIDar allowed me to select what the option would be for the next drive to expand the volume or add dual redundacy. I selected Dual and popped in the 6th 2TB drive. The restripping is now occurring and will take 120 hours!
As I've read this process is increased due to the drive size (not data because the volume is still empty), but I was shocked it will take so long.
Have others had this same experience for time for restriping?
