ewoutgr's avatar
ewoutgr
After reboot Management service not running
Hello,
After a reboot of my Netgear RN102 I'm unable to login to the admin page, the RAIDar Utillity shows "management service is offline"
Can you help me.
Regards Ewout
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Which firmware version is on this unit?
    Can you download the logs using RAIDar 6.0 and then send them in (see the Sending Logs link in my sig)?
    • ewoutgr's avatar
      ewoutgr
      Hello,
      Thanks for your reply, I've just send the logfiles.
      The ReadyNAS is using firmware 6.2.4
      Kind regards.
        mdgm-ntgr
        Looks like there is an issue with your volume.
        Do you have a backup?
ProSupport for Business
