dirkdigs
Dec 09, 2011Aspirant
after removing disk from ultra 4 plus i cant read the disk
i had the hard drive in my readynas but i decided to remove it. now im trying to pull the data off it but windows doesnt recognize it properly. it shows 3 partitions on the disk a first 4GB partiti...
mdgm-ntgr
Dec 09, 2011NETGEAR Employee Retired
The disk is formatted as EXT4, so you'll need EXT4 drivers for your Windows machine or to use a Linux machine.
Why did you decide to remove the drive from the ReadyNAS?
