jduprey
Mar 08, 2013Aspirant
After upgrade ready nas nv[+] has been "booting" for 3 days.
Correction: it is sparc-based NV+. I successfully replaced all 4 of my 500G drives w 2 t drives. After that they still reported being just ~500G in size. As per instructions, I rebooted and after...
fbmachines
Mar 08, 2013Guide
I believe there has been a report from a factory installed 1GB NV+ user also that after 4.1.10 update they ran into the never ending booting issue too.
See long thread about issue...
viewtopic.php?t=69648
If it is indeed the same issue, you're in a tough spot because you don't have the 256MB RAM to swap out and see if it boots. And, your drives are probably not redundant. But at least you have a backup.
