jduprey
Mar 08, 2013Aspirant
After upgrade ready nas nv[+] has been "booting" for 3 days.
Correction: it is sparc-based NV+. I successfully replaced all 4 of my 500G drives w 2 t drives. After that they still reported being just ~500G in size. As per instructions, I rebooted and after...
jduprey
Mar 09, 2013Aspirant
Thanks for the info.
I bought it in 2007 so its not under warranty. I don't know who installed the ram, net gear or the vendor:
"RND4250 READYNASTM NV+ 1 TB GIGABIT DESKTOP NETWORK STORAGE (3 X 500 GB) 5 Year Warranty
Memory Upgrade=*1GB Memory Installed" -- I suspect the vendor.
I'm going to do a factory reset and hope that fixes the problem.. and also hope there were no gaps in my back up.
(I backed up everything using the usb connection, then copied it all to my mac - this alone took days to do. the usb backup was crazy slow, and reading the ext3 disk was not speedy either,=.)
