monneym's avatar
monneym
All settings were reset and can't be changed any longer
I have not logged to my ReadyNAS for some time, it was working fine, and all of a sudden I noticed that the logs are empty, all pre-installed addons are disabled, the newly installed by me dissappear...
  • monneym's avatar
    monneym
    Oct 30, 2015
    Finally, found the proper disk to mount, and here you go
    # df -h
    Filesystem                Size      Used Available Use% Mounted on
    tmpfs                    10.0M         0     10.0M   0% /dev
    /dev/sdd1               119.1M     51.7M     67.4M  43% /sysroot
    /dev/md0                  4.0G      3.8G         0 100% /mnt
    du -sh /mnt
    3.3G    var
    here are the guilty files:
    -rw-r--r--    1 1431056384 Oct 29 00:17 LeafP2P.log
    -rw-r--r--    1 1880812303 Oct 29 00:20 ReadyNAS_Remote.log
    file filled with
    Parsing config
    Service not started
    Error starting application -2
    Well, zeroed those files and things look much better, still missing some addons, but everything is coming along
ProSupport for Business
