monneym
Oct 29, 2015Aspirant
All settings were reset and can't be changed any longer
I have not logged to my ReadyNAS for some time, it was working fine, and all of a sudden I noticed that the logs are empty, all pre-installed addons are disabled, the newly installed by me dissappear...
- Oct 30, 2015
Finally, found the proper disk to mount, and here you go
# df -h
Filesystem Size Used Available Use% Mounted on
tmpfs 10.0M 0 10.0M 0% /dev
/dev/sdd1 119.1M 51.7M 67.4M 43% /sysroot
/dev/md0 4.0G 3.8G 0 100% /mnt
du -sh /mnt
...3.3G var
here are the guilty files:-rw-r--r-- 1 1431056384 Oct 29 00:17 LeafP2P.log
-rw-r--r-- 1 1880812303 Oct 29 00:20 ReadyNAS_Remote.log
file filled withParsing config
Service not started
Error starting application -2
Well, zeroed those files and things look much better, still missing some addons, but everything is coming along
monneym
Yes, I can access the partitions. I used to have ssh, but now it's gone, and I can't install it. When I tried to re-install it, I get: "Update file is not valid for this architecture."
mdgm-ntgr
Oct 29, 2015NETGEAR Employee Retired
That confirms that it is almost certainly a filling OS partition.
Do you have an up to date backup?
