TigerRob
Nov 16, 2016Tutor
All Shares appear to be missing [ReadyNAS Ultra 2; Radiator 4.2.28]
Some weeks ago I (possibly stupidly) ignored a reported filesystem consistency check failure. Have had the check pass successfully since. Today I discovered that I can no longer connect to any o...
TigerRob
Nov 21, 2016Tutor
So, I have a 64-bit JVM. Replacing it with a 32-bit JVM has made my crashplan install work again.
I'm having trouble posting the detail to this thread, my post keeps disappearing. If this is successful then I'll add details.
TigerRob
Nov 21, 2016Tutor
Not sure why I'm having trouble posting the details to this thread. I'm now removing all formatting (although I wasn;t using much before) and hope it'll get through this time.
So, I have a 64-bit Java installation. On investigation the crashplan install script uses "uname -m" to determine which JVM to install, and so on a ReadyNAS will pick a 64-bit bundled JVM. On upgrade the upgrade scripts looks at the installed JVM (whereever JAVACOMMON points) to determine whether to use a 32- or 64-bit version. So, if you installed a 32-bit Java before Crashplan insisted on using the bundled JVM then your upgrades will have stuck to a 32-bit version. For me it weas keeping a 64-bit version, as that was what was bundled when I did my original install.
I simply replaced /usr/local/crashplan/jre with the 32-bit JVM downl;oaded from code42 (see upgrade.properties for the URL) and I have a happy, working Crashplan again.
Thanks all,
Rob.
- StephenBNov 22, 2016Guru - Experienced User
This explains why some users end up with 32 JVMs (with Crashplan working) while others ended up with 64-bit. Thanks for sharing.
