nitro001
Jul 06, 2016Aspirant
Amazon Cloud Drive 1-Way Sync and Encryption
Hello, I have been a long time NV+ user (9 years), and an NV user before that. I wrote a thread a little while ago contemplating updating from the NV+ to a newer model, looking for something that d...
BrianL2
Jul 07, 2016NETGEAR Employee Retired
Hi nitro001,
Amazon Cloud Drive or ACD, does bidirectional (two-way) sync. You can select share/s from your ReadyNAS system that you want to sync with your Amazon Cloud Drive folders. Lastly, the backup or sync is HTTPS (SSL) encrypted.
Kind regards,
BrianL
NETGEAR Community Team
Jul 08, 2016Guru - Experienced User
But the files themselves are not, correct?
- BrianL2Jul 12, 2016NETGEAR Employee Retired
Hi StephenB,
Though we transmit data securely through an encrypted tunnel to ACD, we don't encrypt files.
Kind regards,
BrianL
NETGEAR Community Team- pingjockeySep 10, 2016Tutor
Brian and Readynas team:
File encryption would be an awesome feature to have so that I can securely (well as securet can in a cloud environment) store offsite copies of my files.
- BrianL2Sep 11, 2016NETGEAR Employee Retired
Hi pingjockey,
Your idea to improve the quality and functionality of the product is very much appreciated, and we thank you for sharing your interest in this. You may post this suggestion or idea at the Idea Exchange board. Adding or getting kudos will get more attention from our development team and might get considered to be added to the product's future functionality.Kind regards,
BrianL
