Compact101
Sep 03, 2018Aspirant
Another Cannot connect to Admin Page, ReadyNas Duo
Hi
I've dug my old ReadyNas Duo V1 out as need the storage space.
Everything looks ok, lights, Raidar etc, but I can't connect to the admin page or see on my network.
Before I attempt a factory...
- Sep 03, 2018
You may want to try OS Reinstall first to reset the Network settings or doing a reboot.
If this is an old setup, if you can download the logs it would be worth checking,.
Doing a Factory reset if you have backup of your data would be the fastest route.
Regards
Marc_V
Sep 03, 2018NETGEAR Employee Retired
Hi Compact101
Welcome to the Community!
On RAIDar NAS seems to be fine. Do you have data on this NAS?
Have you checked the IP address of the Workstation trying to connect to this NAS? or have you tried using another PC that is connected on your Network?
If it's still not accessible you may want to try OS Reinstall which resets Network settings, or if you don't have data it would be good to have a fresh setup.
Hope this helps!
Regards
- Compact101Sep 03, 2018Aspirant
Thanks for the quick reply
- The PC accessing it is on the same subnet
- Yes I've tried to connect with another laptop
- Data, I could loose it, if required
I thought I'd try to access as Raidar was looking positive and any reset might be a set backwards.
Will go for the full reset and see what happens.
Thanks
- Marc_VSep 03, 2018NETGEAR Employee Retired
Regards
