GaWd
Feb 17, 2014Luminary
Any way to adjust disk energy saving settings?
I am using Seagate ST32000542AS disks. Every 30 seconds, or so, I can hear one or possibly both hard drives "click" off. All of the smart data looks good to me (but I'm happy to supply it if you need ...
vandermerwe
Feb 17, 2014Master
What model readynas are you referring to ?
You won't be able to change those from raidiator, although there are linux commands there, I think you'd need to hool the drive up to a sata port on your pc and try to do it that way.
You would need a backup before altering settings like that.
I don't know if it's necessary or advisable, the disks are on the HCL for some units and I am not aware of specific firmware that you need on the drive.
