GaWd
Feb 17, 2014Luminary
Any way to adjust disk energy saving settings?
I am using Seagate ST32000542AS disks. Every 30 seconds, or so, I can hear one or possibly both hard drives "click" off. All of the smart data looks good to me (but I'm happy to supply it if you need ...
vandermerwe
Feb 17, 2014Master
Yes, you can't do that from raidiator, you'd need to ssh in.
You would need a backup.
It doesn't sound like this method is supported by seagate though. If they supported it they'd probably have issued a utility to do it.
