Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
LrdShaper
what ip address is it displaying? is it the same as the ip address of your readynas? if it is then be sure to install the certificate permanently on the client browser. if its different then go to Sevices->Standard File Protocols->HTTPS. type your readynas' current ip address in the SSL key host field and click on generate. you'd probably want to set your readynas to have static ip instead of dhcp if you haven't already done so
