Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
gardenphotograp
Feb 16, 2008Aspirant
Thanks LrdShaper!
I had this same certificate error and your solution solved my problem. I hope this also works for Utlover.
