Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
Utlover
Feb 17, 2008Aspirant
Thanks for the update! Unfortunately, this will not help you as when you follow the instruction, you create a dynamic dns entry pointing to your external ip address (the address as supplied by your ISP), whilst the ReadyNas has an internal 192.... address. To me, it appears there will be no way of solving this error. But I'm no expert.
