Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
OppfinnarJocke
Dec 27, 2008Tutor
I have the exact same problem, and frankly I did not understand the answers given. Should it really be that hard...
When I click Setup in RAIDar, Firefox (default browser) throws up a "Secure Connection Failed" saying that <IP num supplied by my ISP> uses an invalide security certificate, not trusted since it is self-signed and only valid for <fixed IP num of the ReadyNAS(?)>. Then I have the option to add an exception, but FF is very harsh on this, do I really, really want...
Well, do I?
(note that FF has no option like IE to "continue to web site anyway")
Well, do I?
