Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
OppfinnarJocke
Dec 28, 2008Tutor
CharlesLaCour wrote: When you add the exception to FireFox what you are doing is telling FireFox that it is OK to trust the certificate from your ReadyNAS. I would assume that you trust your ReadNAS so it is OK to add the exception.
Thanks for this.
The problem with simply adding the exception is that I have to do that every time the NAS gets a new IP-num from my ISP. So I guess I'll have to replace the certificate...
