Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
CharlesLaCour
Dec 28, 2008Aspirant
The FireFox exceptions are stored by IP address and name. If you have a name associated with the ReadyNAS and access it that way instead of the IP address you will not have to add an exception each time there is a new IP address you use to access your ReadyNAS.
