Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
prchrist
Jun 23, 2009Aspirant
Thanks; I'm using https://hostname/user.
The error is 'Mismatched Address'. Currently the certificate is being 'Issued by' and 'Issued to' with the IP for the ReadyNAS.
I.ve tried changing this to both the IP for the PC as well as the IP for the the internet connection from my gateway. I got different errors on one of these indicating that the certificate was invalid as it was 'self-signed'.
When I look in IE7 Security setting I can see the certificate in the 'Trusted Root Certifcates', but continue to get the error.
