Utlover
Feb 15, 2008Aspirant
Any way to get rid of certificate error using Netgear/Jalbum
I followed the instructions from the How to section to setup my ReadyNas Nv+ to act as a webserver and it works flawlessly. So far, so good. The only problem I have is the certificate error which I ca...
CharlesLaCour
Jun 23, 2009Aspirant
If you are accessing the NAS via a name and the certificate is generated based on the IP there will be a name mismatch. If you go into Frontview and go into "Standard File Protocols" under services. Under the HTTPS section place the name you are using to access the NAS in the "SSL key host" and click on the "Generate New Key". When you next access the web interface accept the certificate and trust it and you should be good to go.
