cmassey
Mar 20, 2016Guide
Anyone else having issues with NTFS USB3 External HDD? OS 6.4.2
When running OS6.2.4 everything was running fine, but after the upgrade to OS6.4.2 I can no longer use my NTFS formatted USB3 drive. If I format as FAT32 all looks fine, however as NTFS a 1.5TB driv...
- Mar 27, 2016
So funny story, I've just fixed this while I was fixing my virtualbox issue.
I *think* the issue was the same caused by busybox-kmod.
So I removed busybox-kmod and installed just kmod. That fixed virtualbox and now I just noticed my USB drive is working but I was still having issues an hour ago.
PS, this is for OS6.5.0 BETA 2. The same fix may work with 6.4.2 but I'm not going to try to roll back to test.
cmassey
Mar 21, 2016Guide
Sure why not. Before I do, I assume that 6.5.x will be a new kernel so I would need the NETGEAR Open Source Code for Programmers (GPL).
Yep ran the check tool with no error, currently working perfectly fine in FAT32 (apart from the FAT32 limitations), just goes stupid when I format as the drive as NTFS.
Cheers
mdgm-ntgr
Mar 21, 2016NETGEAR Employee Retired
What do you use the GPL code for?
- cmasseyMar 21, 2016Guide
I use it for VirtualBox. https://community.netgear.com/t5/Community-Add-ons/Virtualbox-on-OS6-NAS/m-p/1063627#M4687
Unless there is a better way to do it?
- mdgm-ntgrMar 21, 2016NETGEAR Employee Retired
Here are the kernel sources for 6.5.0 Beta 2: https://www.readynas.com/download/GPL/readynasos/6.5.0/linux-4.1.19-178-x86_64.tar.xz
- cmasseyMar 22, 2016Guide
Thanks for the info.
I just downloaded the files but won't have time to upgrade until the weekend sometime.
I'll update the thread once the upgrade is complete. Fingers crossed :)
