cmassey
Mar 20, 2016Guide
Anyone else having issues with NTFS USB3 External HDD? OS 6.4.2
When running OS6.2.4 everything was running fine, but after the upgrade to OS6.4.2 I can no longer use my NTFS formatted USB3 drive. If I format as FAT32 all looks fine, however as NTFS a 1.5TB driv...
- Mar 27, 2016
So funny story, I've just fixed this while I was fixing my virtualbox issue.
I *think* the issue was the same caused by busybox-kmod.
So I removed busybox-kmod and installed just kmod. That fixed virtualbox and now I just noticed my USB drive is working but I was still having issues an hour ago.
PS, this is for OS6.5.0 BETA 2. The same fix may work with 6.4.2 but I'm not going to try to roll back to test.
mdgm-ntgr
Mar 21, 2016NETGEAR Employee Retired
Ah.
I can ask engineering if they can provide kernel sources.
