dannieboiz
Oct 02, 2014Tutor
Anyone got 6.2 on their legacy RN yet?
Didn't see any post on this topic, do you install 6.1 from the other thread then just upgrade from frontview?
- mdgm-ntgrNETGEAR Employee RetiredNow that you are running OS6 you can use the standard beta updates and do a manual update.
- screaminleanAspirantHi Guys
first post lol
Any way now I have this ultra 2 running 6.2.3-T1742 can I now download the new standard beta updates and do a manual update? or do I have to wait for one to be compiled for the legacy x86 platform?
Thanks - mdgm-ntgrNETGEAR Employee RetiredNow that you are running OS6 you can use the standard x86_64 builds. When a production update is made available you will even be prompted to update when opening the Dashboard.
- rafal98AspirantI successfully install 6.2 on a ReadyNas Ultra 2, and it is far better than 4.2.27. It's a debian 7 instead of oldish debian 4, it make a big difference. For example g++ is 4.9 instead of 4.1 !!
Just a remark: Fan seems to be a bit loud during a certain amount of time (1400 RPM) then it decrease slowly to about 700 RPM.
And now one question: Is my Ultra 2 can detect update and install it without issue ? I mean, is the official update should work, or do I need a special hacked version to upgrade ?
Thanks a lot :D - uffgnu14LuminaryReadyNAS Ultra 2 Plus.
Just got from OS 6.2.0 to Beta 6.2.1_RC2.
I'm not using my Ultra that much and do not notice any real difference.
I'm still worried about the high CPU temperature.
Nearly always upon start and not under load the CPU-temp is rising up to 70C while the fan speed is constant at low 780rpm.
Anyone noticed this?
See my initial post about this and other findings: http://www.readynas.com/forum/viewtopic.php?f=160&t=78853 - grimlochAspirantI downloaded the 6.2 firmware and updated both boxes manually. They both took about 5 minutes each, 10 at the very most.
I was surprised how quickly they updated.. perhaps due in part to the upgraded processors, but I can't imagine it ever taking 30 minutes even on the stock processor.
Sent from my Nexus 5 using Tapatalk - mdgm-ntgrNETGEAR Employee RetiredIt shouldn't take that long. Perhaps try a reboot
- sgirardTutorHow long this updating should take if you already had the pro at 6.1.9? The reason that I am asking is because I updated via front view and my unit stuck in Booting... Updating firmware for last 30 min or so?
- grimlochAspirantFan speeds seem to finally be working well on both of my Readynas Pros running 6.2. On 6.1.9 the fan wouldn't really kick in until they got to about 85°C.
Both have been upgraded to an Intel E6600 (the cooler version), btw.
Upgraded forked-daapd (iTunes server) that no longer crashes xbmc is also a welcomed edition:)
Sent from my Nexus 5 using Tapatalk - mdgm-ntgrNETGEAR Employee Retiredspin down and fan speeds should be fine.
