Blanker-2's avatar
Jul 05, 2018
Array will not resync
Something happened, not sure what.  My array started resyncing.  It's done this about 3 times so far and it usually completes after about 60 hours or so.  This time though, it's not completing.  At a...
  • StephenB's avatar
    Jul 05, 2018
    Blanker-2 wrote:
    Any opinions or advice would help this noob.  Is there a proper way to replace a bad disk?  Just turn it off, pop out the old and in with the new, and then turn on?
    I recommend doing a hot-swap (pop out the old disk, then insert the new one with the NAS running).  If the new one is formatted, you'll need to format it on the NAS volume page before it is added to the array.
    Blanker-2 wrote:
    After the second time, I then got 9 emails from my nas stating that it's detecting increasing reallocated sector counts on disk 2. (23 times).  My guess is that disk 2 is bad and it cannot resync the array.
    My plan is this, I'm going to try to get back into the nas and hope to sync my nas data to my backup array (before it hits 50% and freezes).
    Try downloading the log zip file, and look at the smart stats for all the drives (either smart_history.log or disk_info.log).  Perhaps also look for disk errors in system.log or kernel.log
    If the only problem is disk 2, you could try simply removing that.  The array would be unprotected (unless you are running RAID-6), but that's no worse than your situation when it is resyncing. Then you could complete your backup and then insert the replacement disk.
ProSupport for Business
