Zeixxs
Jan 06, 2019Aspirant
Asking for help with "RAID level unknown" & "volume root is degraded" errors
Hello, After a firmware update, my Readynas 104 is unusable. I have the following error message: "Volume data RAID level unknown" (see capture). Diagnostics revealed that a disk has "pending sectors" and when I start with 4 disks (exlcuding the one with pending sectors) I get "volume root is degraded". I know my data is intact I was able to see parts of it with ReclaiMe. But I cannot pay 200$ for the full recovery licence. My Netgear warranty is over and my data is not important enough to pay hundreds to maybe recover it. Is there any way to repair the root sector? Or at least to recover some data before doing a factoty reset (and formating)? Thanks a lot to anyone who can help me out.
I think you must mean 3 disks, since there are only four bays total in the RN104. Are you able to access your data when you boot the system this way?
To clarify - a "degraded volume" is one that is no longer protected by RAID redundancy, but which is still accessible. If you are seeing "corrupt root", then that is another matter.
- ZeixxsAspirant
Hello and thank you for answering.
You're right, I meant 3 disks, sorry.
When I start with 4 disks I get the "disk 2 has pending sectors" and when I start with 3 disks (excluding the 2nd), I get "Volume root is degraded" and "md/raid:md127: failed to run raid set." when I use the diagnostic from RAIDAR.
I cannot access my data either with 3 or 4 disks.
I get to the 1st folder level (Videos, Pictures, ... but I click I get a network error message saying windows cannot access (error code 0x80070043).
Can you log into the NAS web UI?
