armornone
Jan 13, 2013Aspirant
ATA errors at 42, should I return hard drive?
Hello. 3 out of 4 of my hard drives have ATA errors at 46. I am wondering if I should return the hard drives or just watch with caution? What exactly is an ATA error and is it like reallocated...
armornone
Jan 15, 2013Aspirant
mdgm wrote: So is the count 42 or 46?
If you download the logs (Status > Logs > Download all logs) and extract the zip contents what does partition.log look like?
I originally thought it was 46 but as I looked at at the S.M.A.R.T report, it did say 42 not 46.
I did experience a power outage during the expansion/syncing of one of the expansion hard drives.
Here are the log files you asked for from Partition.log:
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hda: 1020 MB, 1020837888 bytes
16 heads, 63 sectors/track, 1978 cylinders, total 1993824 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hda1 32 1993823 996896 6 FAT16
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 3907008687 1951200343 5 Extended
/dev/hdc5 4608003 1465112305 730252151+ 8e Linux LVM
/dev/hdc6 1465112312 3906992303 1220939996 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 2 4096001 2048000 83 Linux
/dev/hdg2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdg3 4608002 3907008687 1951200343 5 Extended
/dev/hdg5 4608003 3906992297 1951192147+ 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
/dev/hdi1 2 4096001 2048000 83 Linux
/dev/hdi2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdi3 4608002 3907008687 1951200343 5 Extended
/dev/hdi5 4608003 3906992297 1951192147+ 8e Linux LVM
