6speed1
Jun 24, 2015Aspirant
Automatic shutdown on drive failure
Is there a way to disable the automatic shutdown when a drive fails? I know the obvious answer is to replace the drive and re-sync but this process is failing at about 90% which causes the system t...
Jun 24, 2015Guru - Experienced User
Well, the data likely will be corrupted, but hopefully the bulk of it will be intact.
Ixa wrote:
6speed wrote: I am trying to get the data off the volume but it either shuts down when the failed drive is missing or crashes trying to rebuild the array.
You may want to clone the failed drive. After the cloning process, insert the cloned drive and the data should be fine.
