6speed1
Jun 24, 2015Aspirant
Automatic shutdown on drive failure
Is there a way to disable the automatic shutdown when a drive fails? I know the obvious answer is to replace the drive and re-sync but this process is failing at about 90% which causes the system t...
6speed1
Jun 25, 2015Aspirant
Nhellie wrote: Is this for an NV+?
Go to System>Alerts>Settings then uncheck Power-off NAS when a disk fails or no longer responds. >Click Apply
Yeah, it's a NV+.
You are so the man! You just saved my data.
