6speed1
Jun 24, 2015Aspirant
Automatic shutdown on drive failure
Is there a way to disable the automatic shutdown when a drive fails? I know the obvious answer is to replace the drive and re-sync but this process is failing at about 90% which causes the system t...
Nhellie
Jun 25, 2015Virtuoso
6speed wrote:
Yeah, it's a NV+.
You are so the man! You just saved my data.
Good to know! :D
That feature is to protect the data BTW, it shuts down to avoid another failure. Not recommended to be unchecked if you cannot get access to the NAS locally and replace the failed drive.
