6speed1
Jun 24, 2015Aspirant
Automatic shutdown on drive failure
Is there a way to disable the automatic shutdown when a drive fails? I know the obvious answer is to replace the drive and re-sync but this process is failing at about 90% which causes the system t...
6speed1
Jun 25, 2015Aspirant
Nhellie wrote: Good to know! :D
That feature is to protect the data BTW, it shuts down to avoid another failure. Not recommended to be unchecked if you cannot get access to the NAS locally and replace the failed drive.
It's sitting right next to me and I'm backing up all the data that's still good.
Reminder to self. RAID is not a backup and keep your backups up to date. :slap:
