6speed1
Jun 24, 2015Aspirant
Automatic shutdown on drive failure
Is there a way to disable the automatic shutdown when a drive fails? I know the obvious answer is to replace the drive and re-sync but this process is failing at about 90% which causes the system t...
mdgm-ntgr
Jun 29, 2015NETGEAR Employee Retired
6speed wrote: Is there a way to disable the automatic shutdown when a drive fails?
Should just need to alter one line in /etc/default/services I think to change this behaviour.
