Lennardo
Sep 06, 2016Tutor
automatically boot and shutdown for backup
Hallo,
i have a ReadyNAS 516 with my data and a old ReadyNAS314 which i want to use for backup. I got it running and backing up fine. But i cant find a option to shutdown RN314 after backup is finished. I found the power timer. But this allows me just to start up at a time (okay, thats what i want) and shut down at a time (this i dont want). Is there a way to tell RN314 to shut down after the backup is finished (and not too early)?
Thank you
Lennardo
- omicron_persei8LuminaryWhat about if you have two jobs (job1 schedule is 00:05-02:05, job2 is 01:05 to 03:05). Power schedule is 00:00-02:00.
If job1 is not finished at 02:00, the NAS won't shutdown, fine. But would job2 start before shutdown? Or would the NAS shutdown straight after job1 completes?
Without power schedule, job2 would only start from 01:05 after job1 is complete or forced start at 03:05 regardless of job1 status.- LennardoTutor
I got a log entry 'scheduled power-off was delayed'. So it seems the backupjob has priority above power-off. I am test now some sitruation and will give feedback in a few days.
Lennardo
- cathcamGuide
Also, since my backup NAS is in the basement, I enabled Wake on Lan and can use a number of programs on my laptop or even my phone when connected to wifi to wakeup and Power-on the NAS. This allows me to run adhoc backups/restores without trecking down to the basement to switch the NVX NAS on.
- cathcamGuide
I have a daily backup job scheduled for midnight. I'll set the NAS to power-up at 11:45, do a 145Gb backup and power off at 00:05, I doubt the backup will be complete and I can see if it powers off...
- cathcamGuide
I'm interested in an answer to this. Over on this thread it says "If the backup is running it should not power off."
