hasse_A
Jul 19, 2020Follower
Backing up from a ReadyNAS Ultra 4 to a remote ReadyNAS 104.
The Ultra 4 has got Firmware 4.2.1 and the 104 has 6.10.3 I have configured the 104 as the remote server to where I want to backup my data on the Ultra 4 using rsync. When trying to do a backup I ...
Jul 19, 2020Guru - Experienced User
While you could convert your Ultra to run OS-6, I don't think that's your problem. I back up between OS-6 and 4.2.x systems all the time.
Is rsync enabled on the remote share?
Is there a firewall on the path that might be blocking the connection?
Are both NAS on your home network?
