davidr1
Oct 18, 2015Luminary
Backing up to 4TB usb hdd problems
Hi NAS 314 OS6 v 6.2.4 4TB Seagate HDD I have problems backing up to my usb hdd. I am (trying) to backup an approx 1.34TB share. The maximum depth is about 7 subfolders and contents. There are...
davidr1
Oct 19, 2015Luminary
How do I mark this as unsolved?
I never marked it as solved yet it says it is! I temporarily lost connectin to this page that is all.
Will this be read or should I repost?
Back to my first post:
formatted by gparted to to ext3, the backup finished. No errors reported but I will be checking to confirm.
So,
- formatting 4TB drives in OS6 to ext3 or ext4 does not work.
- I don't know where the full backup log is - IMHO it should be easily
- Perhaps attaching the log file to the email for 'Full Backup Logs' instead of putting the list in line would better.
IMHO OS6 should handle 4TB drives correctly. Yes, it should keep up with drive sizes that linux is able to handle or give a categoric warning in the pdf files what the size limitation is.
motts1983, yes, the limititations of MBR addressing requires GPT for >2TB.
David
davidr1
Oct 21, 2015Luminary
Polite 'ping' .....
