fearlesss
Jan 27, 2015Aspirant
Backing up to Drop Box for ReadyNAS 104 #24518168
Hey guys, I've done a search on the forums, google and tried talking to the Netgear support ( which kindly suggested I pay them MORE money for any support.... ) because paying for the product itself ...
fearlesss
Mar 12, 2015Aspirant
I've tried re doing the backup re syncing the drive to drop box,
The problem is not that it's not working , it is working .. I just don't have any way of knowing what files have been backed up, if it's currently backing files up , when the last back up was ? there is no details about anything all there is a button that says on, the option to select which share I want to back up and a sync button :/
Thanks sdouek, I've already bought a years worth of dropbox so I'll check out crashplan when that runs out.
hilgert
Jul 24, 2015Aspirant
Any update on this? Amazingly, after several years, this issue remains on the otherwise fine ReadyNAS product. This is one of the orginal reasons I purchased my ReadNAS 102, but I've had to use workarounds in order to get *reliable* dropbox functionality (basically I have an intermediary computer delgated to just DropBox sync since the ReadyNAS DropBox sync is unreliable).
