jc2010
Jan 28, 2011Aspirant
Backup Connection Error
I'm trying to backup my PC (Windows Vista, 64-bit) using Frontview. The PC and ReadyNAS are both on my local home network, and I don't have a login/password on my computer. I've selected "Remote: Windows/NAS (Timestamp)" as the backup type, the PC's IP address (192.168.1.64) as the host, and "C$" as the path. But when I select "Test Connection", I get "Error connecting to //192.168.1.64/C$" I've also tried using "C:\Users\John\Documents" as my path, but I get the same type of error - "Error connecting to //192.168.1.64/C:\Users\John\Documents". Please help!
- lockvkfAspirant@ewok, in reply to Mar14 3:19pm post...
I connected to my Win7 laptop from a XP Pro machine fine over my home Lan wirelessly (supplying my Win7 user/pwd).
When I run the job as suggested, it runs successfully! I then test the connection (of the successfully completely job) and again it errors with the same error message I have posted here.
It seems the test connection doesn't work. It did use to work, at least under XP and Vista. - Old_Man1AspirantHello,
This is the Old Man that knows just enough to be **VERY**VERY** dangerous.
I just got my ReadyNAS Ultra 4 yesterday and equiped it with 4 2TB drives setup in Raid 5 configuration. I can connect via Windows Explorer and Internet Explorer and am successfully adding Shares and Users to transfer files from all local PCs to the NAS via Windows Explorer.
However, I only get the "Connection Failed" message when testing connections while setting up a backup job. I have two Windows Vista Home systems and even added a 'non-primary' account for the NAS as recommended in previous posts. I changed each PC to share the C: drive with no difference. I can access the C: drive from each PC to the other PC without error upon primary account login and they appear in the local network landscape automatically.
Where else can I look???
Chuck - ewokNETGEAR ExpertTry running the backup job and see if you get a more informative error message.
- westysonAspirantI am having the same problems with connection. Here isa copy of the error log
LL Backup started. Wed Mar 30 23:27:16 WEST 2011
Job: 001
Protocol: cifs
Source: //192.168.0.7/C$
Destination: [backup]/
Backup failed. Wed Mar 30 23:27:18 WEST 2011.
Reason for failure:
Unable to access remote path //192.168.0.7/C$.
The host being the IP address and my C drive being the path. This is using Windows 7.
User name and password filled in, but no luck.
Any help very much appreciated.
Thanks - sansmithAspirantI also am having a similar issue. I have 3 PC notebooks that the NAS can communicate with and the backups work.
They are Vista upgrades to Win7. The one that cannot connect is a Toshiba Satellite A665 32 bit OEM Win 7 Home Premium.
I am using v4.1.6 for the NV+ nas and v4.30 for the RAIDar config utility. I have tried using the hostname,a static IP, and setting the NAS as the WINS server, both do not solve the issue with being able to see that notebook.
Is there a computer name restriction? This workstation has 11 letters with no spaces.
Seems there is an issue with Win7 and backup for this particular workstation. Any ideas would be appreciated. - Old_Man1AspirantI ran the job - the error message does not help much. Any other idea's?
FULL Backup started. Fri Mar 25 00:05:02 EDT 2011
Job: 001
Protocol: cifs
Source: //chuckadmin-pc/c:users/chuckadmin/documents
Destination: [Chuck_Backup]/
Backup failed. Fri Mar 25 00:05:05 EDT 2011.
Reason for failure:
Unable to access remote path //chuckadmin-pc/c:users/chuckadmin/documents. - PapaBear1ApprenticeOld Man - I looked at your setting and it does not match the choices available on my NV+. I don't know how you selected CIFS as that is not one of the choices.
Here is a screenshot of a test job I set up for another discussion:
In the host blank P35DS3P is the computer name, but the IP could be used as well. I generally use the name for the computers, but eh IP addresses for the NASes on the network. The path does not include C: which is the root in Windows. That is not stated in Linux but understood. In my example Data is a first level directory. Lower level directories would be separated by a forward slash. An example could be: Data/Documents/Legal.
The above example was set up as a test, P35DS3P is my main desktop and primarily runs Windows 7 Home Premium (64 bit), however, it still has Vista Home Premium (32 bit) on another drive and I ran the test on it as well. The test connection was successful and I copies about 3 GB of data into the directory Data (set up only for the test) and the backup ran and completed successfully. I always do better with examples, and thought you could use one. - Old_Man1AspirantThanks for the fast reply. I'll try it and post the results. BTW - CIFS was somehow put as a default as I never explicitly selected it.
Old Man - Old_Man1AspirantTried again - confirmed your configuration - same error
FULL Backup started. Sat Apr 2 07:23:19 EDT 2011
Job: 001
Protocol: cifs
Source: //chuckadmin-pc/users/chuckadmin/documents
Destination: [Chuck_Backup]/Documents
Backup failed. Sat Apr 2 07:23:22 EDT 2011.
Reason for failure:
Unable to access remote path //chuckadmin-pc/users/chuckadmin/documents. - ewokNETGEAR ExpertDo you have a shared folder called "users" on the PC?
