msd
Dec 19, 2015Luminary
Backup Exclusions don't show using Alternate Browsers
Hi, OS 6.4.1 I have a problem. I set an Rsync Backup job and set an Exclusion. The pop up Browse Windows don't work with any Browser, Chrome, Firefox, IE11). Regardless, I Typed in the folder na...
- Dec 20, 2015
One can close off this post as "Resolved" I have worked out the issue.
- My issue was self inflicted. I discovered, that the "Test" folder I was looking at on the USB_hdd_1 was a standalone folder I created for a different job. The Main Rsyn Job wasn't even looking at it hence the reason nothing was changing (oops). :smileyfrustrated:
- I have since being informed by Netgear Support that the "Pop Up" window in Backup/Advanced doesn't work. Its not a deal breaker as long as one knows how to Exclude a Folder. This is easy enough by just Typing the name of the Folder OR Path to Folder and adding.
CACHE: Is definately a concern with OS6 and often a full "Page Refesh" is required to clear what showed last time around. It's one reason I sometimes hate "Web Style" interfaces. They can be dangerous if one forgets. This however had no bearing on my "non existant" issue!
Thanks for reply.
Case Closed
mdgm-ntgr
Dec 20, 2015NETGEAR Employee Retired
Have you tried clearing your web browser cache, closing your web browser then reopening the web admin page and checking again?
- msdDec 20, 2015Luminary
Did you read original Post?. I tested using 3 Browsers and also on 2 different PC's! How can clearing Browser Cache assist.?
PS: I refuse to ever clear my Browser Cache and it being used as an excuse. I like my Browser Cache. One can always Refresh which will do much the same.
To be certain: I work around this by using a Different Browser OR different PC :-)
Cheers
Thanks for reply.
Case Closed
- BrianL2Dec 21, 2015NETGEAR Employee Retired
Hi msd,
This post has been tagged as resolved. Also, a big thanks for the share and the workaround that you did to resolve your problem.
Kind regards,
BrianL
NETGEAR Community Team
