msd
Dec 19, 2015Luminary
Backup Exclusions don't show using Alternate Browsers
Hi, OS 6.4.1 I have a problem. I set an Rsync Backup job and set an Exclusion. The pop up Browse Windows don't work with any Browser, Chrome, Firefox, IE11). Regardless, I Typed in the folder na...
- Dec 20, 2015
One can close off this post as "Resolved" I have worked out the issue.
- My issue was self inflicted. I discovered, that the "Test" folder I was looking at on the USB_hdd_1 was a standalone folder I created for a different job. The Main Rsyn Job wasn't even looking at it hence the reason nothing was changing (oops). :smileyfrustrated:
- I have since being informed by Netgear Support that the "Pop Up" window in Backup/Advanced doesn't work. Its not a deal breaker as long as one knows how to Exclude a Folder. This is easy enough by just Typing the name of the Folder OR Path to Folder and adding.
CACHE: Is definately a concern with OS6 and often a full "Page Refesh" is required to clear what showed last time around. It's one reason I sometimes hate "Web Style" interfaces. They can be dangerous if one forgets. This however had no bearing on my "non existant" issue!
Thanks for reply.
Case Closed
mdgm-ntgr
Dec 20, 2015NETGEAR Employee Retired
Have you tried clearing your web browser cache, closing your web browser then reopening the web admin page and checking again?
msd
Dec 20, 2015Luminary
Did you read original Post?. I tested using 3 Browsers and also on 2 different PC's! How can clearing Browser Cache assist.?
PS: I refuse to ever clear my Browser Cache and it being used as an excuse. I like my Browser Cache. One can always Refresh which will do much the same.
To be certain: I work around this by using a Different Browser OR different PC :-)
Cheers
- msdDec 20, 2015Luminary
Thanks for reply.
Case Closed
- BrianL2Dec 21, 2015NETGEAR Employee Retired
Hi msd,
This post has been tagged as resolved. Also, a big thanks for the share and the workaround that you did to resolve your problem.
Kind regards,
BrianL
NETGEAR Community Team
