geek2b
Feb 10, 2017Aspirant
Backup from Usb to RAIDiator 4 system
Hi. I am new to the community, and having issue with backup from USB to Volume C. tried to setup using fornt usb as well as rear. but having same error. Any help will be appriciated. ----------...
- Feb 10, 2017
the path is / (on usb), and i tried to do that as well.
During the attempts, i found the issue and it's now resolved. Following is the detail, for KB purpose:
1) Front-View (control panel), in the volumes section (in USB Storage), i could see the attached USB. Which means that is plugged2) Though it wouldn't shown as shared-resource in bakcup-jobs creation page.
3) the USB had files, and worked perfectly on my windows system (filesystem of USB was exFAT).
But it wasn't showing it's file system in the USB-Storage pane in the Front-View.
So i used other usb, formated with FAT filesystem, put some files.
When other USB formated in the right filesystem, that also worked.
This can be a bug, IDK. But the bug can be created by using the mentioned filesystem.
Thanks for reply, vandermerwe.
<happy coding />
vandermerwe
Feb 10, 2017Master
Did you try entering a path for the source?
- geek2bFeb 10, 2017Aspirant
<happy coding />- SandsharkFeb 11, 2017Sensei
There is an ExFAT package for Debian Jessie and Wheezy, so OS6.x users can add it via SSH, but nothing for Lenny or Etch, so OS 4.x and 5.x users are out of luck. I think Netgear should consider making it a part of the OS6.7 release.
- geek2bFeb 11, 2017Aspirant
Thanks for valuable info, on package.
+1 on Netgear should consider making ExFAT package for Debian a part of the OS6.7 release
<happy coding />
