craer
Aug 03, 2017Aspirant
Backup home folders on ReadyNAS 528X using replicate
Finely i am able to get a real backup solution set up using my old ready nas's, after losing most files when readycloud went down this yea.... i am trying to get home folders (where i put most...
- Aug 08, 2017
craer wrote:
i dont know if the router where the remote nas will be has a dns on it. (YET)
cause i would rather push if i could chouse.
To be clear, you want DDNS, not ordinary DNS. If the router doesn't support it, you can also install a DDNS client on a PC in that location.
craer wrote:
i am using the moth on INT ips so exp:192.168.1.10 for Nas A and 192.168.1.20 for Nas B
not sure if i nead to open the port 22 when i get it working on Int IP and more it over to
EXT IP ( over the internet)
Of course test the backup job on your local network.
Later on (for push) you will need to replace the IP address for NAS B with the DDNS name. And you will need to forward port 22 on the router for NAS B.
craer wrote:
did you see and thing else i did wrong on any other part of the setup? such as the shair ? its a shair strait off the main root Data/(share name)
Again, getting the backup(s) working on the local lan will flush out any mistakes in the backup job settings. In general, you will need rsync enabled for the destination share(s) on NAS B.
Aug 03, 2017Guru - Experienced User
You should be using rsync over ssh, since this is going over the internet. There's a guide here: https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-with-rsync-over-SSH
You will also want to deploy DDNS (dynamic DNS) on the remote system, so NAS A can reach NAS B using a name instead of an IP address that can change without notice.
craer
Aug 04, 2017Aspirant
first thanks guys i did get a test working using No SSH..
just a few things
what does it meen to set up a time from-till...? would it not just be here start at this time.
next working on the ssh part i am following the guide BUT its telling me "netgear may deny support if i turn ssh on.. is this true ad why?
lastly tell me more on how to set up the dns part i do like a host name it probly better then no-ip.. and this remote nas will be over 2000m away once i set it up
once more thanks
- StephenBAug 04, 2017Guru - Experienced User
Support policies for that are here: https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides
If you are simply installing certs and enabling rsync over ssh, you won't run into trouble here.
You'll need dynamic DNS. There are some free providers (noip.com being one). Most newer routers have support for this - can you tell us what routers you have on both sites?
- craerAug 05, 2017Aspirant
i have a netgear ac1900 i prity sure.
and the remote side is a stock verizon vios all in one dumb thing.
i dident know if there was anything that the RN can host its self
and thanks i will readup on the ssh
its bin a wile since i used ssh but never realy understanded what it did
i will try all of this thanks
- StephenBAug 05, 2017Guru - Experienced User
To be clear - the idea here is to tunnel rsync over ssh, in order to get an encrypted connection. The guide I linked before ( https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-with-rsync-over-SSH ) has all you need to know. You don't need to use any ssh commands.
Nighthawk routers do include DDNS support (including the ability to get a free xxxx.mynetgear.com DDNS name). If that's what you have, then you'd forward port 22 in the Nighthawk to your NAS. The far end system would initiate the backup ("pull" backup), and it would use the DDNS name you get for the Nighthawk.
