thenags
Feb 28, 2020Aspirant
Backup issues with ReadyNAS 524X
We've got some backups going from this NAS to another identical NAS over a VPN. All permissions are set properly and the 'Test' connection button shows all is good. However I keep getting the follo...
Feb 28, 2020Guru - Experienced User
Did you try going into the file access tab of the destination share settings, and resetting the file permissions (using the RESET control on the left) ?
thenags
Mar 04, 2020Aspirant
I hadn't but I did just now and restarted the job. I'll report back later with an update.
Thanks.
