mattmcl1
Jan 01, 2008Aspirant
Backup not working
I haven't run my regular backup jobs for a month. In that time I have: Replaced disk #1 after failure & resynced Replaced disk #2 after failure & resynced Upgraded to version 4 of FrontView N...
mark12345
Dec 25, 2009Aspirant
Help!
Background:
Host: Windows XP
ReadyNas NV+
Firmware 4.1.6
Running as Administrator on the ReadyNas and on the XP host
I have been trying to get backup jobs to work via Frontview for a ~week now. Tried both IP and host name to no avail. I just got a test case to work, but it required the folder to be backed up to be shared. Why won't a non-shared connect?
The test follows:
1. Created a folder c:\aaa
2. Created a .txt document within this folder
3. Attempted to backup using Windows Timestamp
4. Results: unable to connect
5. Made the folder c:\aaa fully shared
6. Was able to connect
7. Backup was successful
8. Then made c:\aaa unshared and repeated
9. Backup failed (logs follow)
INCREMENTAL Backup started. Fri Dec 25 21:53:39 EST 2009
Job: 001
Protocol: cifs
Source: //airplane/aaa
Destination: [backup]/
Backup failed. Fri Dec 25 21:54:05 EST 2009.
Reason for failure:
Unable to access remote path //airplane/aaa.
INCREMENTAL Backup started. Fri Dec 25 21:51:05 EST 2009
Job: 001
Protocol: cifs
`/job_001//New Text Document.txt' -> `/backup/New Text Document.txt'
Backup finished. Fri Dec 25 21:51:12 EST 2009
FULL Backup started. Fri Dec 25 21:48:07 EST 2009
Job: 001
Protocol: cifs
Backup finished. Fri Dec 25 21:48:10 EST 2009
Background:
Host: Windows XP
ReadyNas NV+
Firmware 4.1.6
The test follows:
Job: 001
Protocol: cifs
Reason for failure:
Job: 001
Protocol: cifs
Job: 001
Protocol: cifs
