md96
Aug 10, 2012Aspirant
Backup on Duo v2 and Window 7 64 bit
After reading about 15-20 posts here and elsewhere on the web and spending about 2-3 hours with the Netgear tech support staff, I figured out how to resolve the problems I was having using the Duo v2 ...
md96
Aug 21, 2012Aspirant
Yes, that *should* work, but.. both the Netgear level 2 support person (via remote control of my PC) and I had tried to set up the backup using my main Win 7 login and *it didn't work* (even with "everyone" write privileges). The only thing that fixed it was adding a different user. I'm not sure why that worked for my case, but I suggest those having difficulties give it a try. And, yes, I didn't want my work folder to be open to "everyone" when I take my laptop to work.
