md96
Aug 10, 2012Aspirant
Backup on Duo v2 and Window 7 64 bit
After reading about 15-20 posts here and elsewhere on the web and spending about 2-3 hours with the Netgear tech support staff, I figured out how to resolve the problems I was having using the Duo v2 ...
DavidBulluss
Apr 15, 2013Aspirant
Hi, I am fairly new at this having only started setting my Duo V2 up about a week ago.... and it is taking time!
I was having big problems getting back up from my remote win 7 notebook to the readynas but it all seems to be going well now (thanks partly to this thread for the login hint!) except that after the backup is seemingly complete I get the following email advice
"INCREMENTAL Backup started. Mon Apr 15 17:36:26 PDT 2013
Job: asusnotebook D
Protocol: cifs-ab
Source: //asusnotebook17/d/work files?
Destination: [backup]/ASUSNOTEBOOK 17
Unknown parameter encountered: "min receivefile size"
Ignoring unknown parameter "min receivefile size"
session setup failed: SUCCESS - 0
Files copied: 0
Backup finished. Mon Apr 15 17:36:27 PDT 2013"
Does that mean that my backup settings are not targetting any files?
Help!!!
Thanks all.
Job: asusnotebook D
Protocol: cifs-ab
Files copied: 0
Help!!!
Thanks all.
