md96
Aug 10, 2012Aspirant
Backup on Duo v2 and Window 7 64 bit
After reading about 15-20 posts here and elsewhere on the web and spending about 2-3 hours with the Netgear tech support staff, I figured out how to resolve the problems I was having using the Duo v2 ...
Amidala
Apr 24, 2013NETGEAR Employee Retired
md96 wrote: Yes, that *should* work, but.. both the Netgear level 2 support person (via remote control of my PC) and I had tried to set up the backup using my main Win 7 login and *it didn't work* (even with "everyone" write privileges). The only thing that fixed it was adding a different user. I'm not sure why that worked for my case, but I suggest those having difficulties give it a try. And, yes, I didn't want my work folder to be open to "everyone" when I take my laptop to work.
As you said, I tried "Everyone" and "a specified user" to the sharing folder for MY Win 7.
If choose "Everyone", "test connection" failed.
INCREMENTAL Backup started. Wed Apr 24 19:56:22 PDT 2013
Job: 22
Protocol: cifs
Source: //10.40.0.104/RAIDar
Destination: [backup]/
Backup failed. Wed Apr 24 19:56:22 PDT 2013.
Reason for failure:
Unable to access remote path //10.40.0.104/RAIDar.
If choose "a specified user", "test connection" completed.
FULL Backup started. Wed Apr 24 19:55:57 PDT 2013
Job: 22
Protocol: cifs
`/job_014//RAIDar_Win_4_3_6.exe' -> `/backup/RAIDar_Win_4_3_6.exe'
Backup finished. Wed Apr 24 19:56:01 PDT 2013
