NASklr
Sep 19, 2015Aspirant
Backup Path Lost When Switching USB Drives
RN102 with 6.2.3 I have backup jobs for each share to backup to a corresponding destination folder on a usb drive (Music share goes to Music folder on usb drive). Backup button is enabled for each j...
Sep 23, 2015Guru - Experienced User
NASklr wrote:
I'm reluctant to test out a beta firmware at this point.
You can't downgrade from 6.4 beta, so it is wise to be cautious.
You could upgrade to the current production firmware though (6.2.5).
NASklr
Sep 23, 2015Aspirant
Restoring to factory default and updating to 6.2.5 is on my list. Right now my backup enclosures are in use getting some 3TB drives toture tested prior to installing in the RN102.
- NASklrSep 29, 2015Aspirant
Restored to factory default, updated firmware to 6.2.5, then restored from previous configuration. So far so good. usb_hdd_1 was recognized without having to redfine the backup paths.
- BrianL2Sep 29, 2015NETGEAR Employee Retired
Hi NASklr,
Thank you for the feedback. Just let us know if you encounter such problems again with the USB path on your backup jobs.
Kind regards,
BrianL
NETGEAR Community Team - NASklrOct 27, 2015Aspirant
I can now confirm updating to 6.2.5 firmware took care of my issue. Due to drive upgrades I was back to scratch on all my backup jobs. Since I swap backup drives out every month it took a number of months before I had reconnected both backup drives at least once.
