PatrickJohnson1
Oct 23, 2018Aspirant
Backup Questions
Question 1
Do i need internet connect to back my data on my ReadyNAs 3138? Besides the ReadyNAS is connected to our Cisco switch for hich every other nodes are connected.
Question 2
Am ...
- Oct 23, 2018
Welcome to the Community!
Question 1
If you will be doing local backups then using internet connection won't be necessary. This is needed if you will backup from a remote server/location.
Question 2
Am managing up to 50 computers on my Microsoft window Active directory and am looking for the best way to backup each computer to my ReadyNAS with comsuming my bandwidth
There are backup methods used by ReadyNAS. You can check them here ReadyNAS Backup FAQ. You may want to use Windows/NAS (Timestamp) or Rsync backup.
Connecting your NAS on the Internet is also important for updates or fixes and remote access.
Hope this helps!
Regards
Marc_V
Oct 23, 2018NETGEAR Employee Retired
Question 1
Question 2
Hope this helps!
Regards
PatrickJohnson1
Oct 24, 2018Aspirant
Thanks Marc_V
- Sep 19, 2018Retired_Member
