PatrickJohnson1
Oct 23, 2018Aspirant
Backup Questions
Question 1
Do i need internet connect to back my data on my ReadyNAs 3138? Besides the ReadyNAS is connected to our Cisco switch for hich every other nodes are connected.
Question 2
Am ...
- Oct 23, 2018
Welcome to the Community!
Question 1
If you will be doing local backups then using internet connection won't be necessary. This is needed if you will backup from a remote server/location.
Question 2
Am managing up to 50 computers on my Microsoft window Active directory and am looking for the best way to backup each computer to my ReadyNAS with comsuming my bandwidth
There are backup methods used by ReadyNAS. You can check them here ReadyNAS Backup FAQ. You may want to use Windows/NAS (Timestamp) or Rsync backup.
Connecting your NAS on the Internet is also important for updates or fixes and remote access.
Hope this helps!
Regards
Oct 23, 2018Guru - Experienced User
Although you don't need an internet connection for backup, it does have a couple of consequences. The Antivirus definitions won't be updated, and also your system won't receive the hot fixes that Netgear sometimes pushes.
PatrickJohnson1
Oct 24, 2018Aspirant
Thanks
- Sep 19, 2018Retired_Member
